30lb roofing felt under hardwood
Old 08-18-06, 06:13 PM
B
I'm getting ready to install 3/4" t&g hardwood. I plan to use roofing felt underneath. I have a roll of 30 lb left over from a roofing project. Is that ok to use? Or should I stick with 15lb?
Thanks,
Brian
Old 08-20-06, 08:28 AM
D
Received 2 Upvotes on 2 Posts
Not a pro but I thought this might help you
https://www.nofma.org/Portals/0/Publications/NOFMA%20Installing%20Hardwood%20Floors.pdf
I see you should use the 15lb but always stick with the manufacturers instructions as not doing so will void your warranty.
