armstrong laminate
Instructions state a t-moulding spacer needs to be placed if area to be covered is greater than 26 feet in width. The width of the room we are installing is 29 feet. Does anyone have knowledge about this?
Do we need a spacer since it is only a "little" bigger than rec.?
I think it would look better without a spacer, but don't want the floor to come apart.
daralyn
daralyn
Personally I would risk it (for 3 feet) - unless you have a convenient place to put this strip.
It wont cause the floor to come apart - but it may cause it to "buckle". The reason for this strip is for expansion and contraction.
