removing new hardwood flooring
Old 09-03-06, 07:15 AM
W
I'm replacing a 50 SQ FT area of glued down hardwood flooring with ceramic tile.How do I remove the glue residue from the concrete below? (It's very sticky) This is on a concrete slab home
Old 09-03-06, 07:38 AM
D
Received 2 Upvotes on 2 Posts
Are you sure you want to remove the hardwood floor? Is it really bad?
Here's a previous thread that should help you.
http://forum.doityourself.com/showthread.php?t=268679&highlight=remove+hardwood+floor
(copy and paste)
If it doesn't, please let us know.
Old 09-03-06, 08:00 AM
W
I'm sure we want to remove it. It was not a good product and we are replacing the carpet in the rest of the house with shaw laminate that is a different color. After I removed a few boards it's not solid hardwood but plywood with a top veneer layer.
Old 09-04-06, 12:58 AM
Razor scraper to get the adhesive off the substrate.
Old 09-04-06, 06:01 AM
W
I bought a 4 inch scraper and put boiling water on it.Most of it came off. Thanks for the help! The tile is in and it looks great. Your how to articles helped alot.
I did however undercut the doorjambs too much, going to have to fill in the gap with something- the gap is wider than caulk will fix.
