Dupont Real Touch Flooring and Concrete Subfloor
Old 09-24-06, 05:26 PM
Hi. Very help forum here!
I am researching in preparing to lay laminate flooring myself. Sometimes it seems doable, then sometimes daunting!
First Q----I am looking at using the Dupont Real Touch laminate. It has the pre-installed foam underlayment on each piece. Is this good enough for laying on concrete? or do I still need to put down the foam rolls? (I can't find a concrete answer on this at Dupont..pardon the pun
Second Q---regarding my concrete subfloor. It appears that around the wall, there is about a 5 inch concrete section, and then a space, and then the concrete slab (like a slab within a concrete frame....make any sense???). There is roughness at the cracks' meeting on each side, which I'll need to ground down, but the "crack" is only .5" or so wide....Do I need to fill that crack in? or can I just lay the laminate normally?? I think it'll be ok based on what I have researched, but I wanted your opinions.
Thanks so much!
Old 09-25-06, 03:59 PM
You need to make sure the substrate meets the standard 1/8 inch in 6 feet, for flatness requirements.
You must use a plastic moisture barrier over the concrete, first.
Old 09-26-06, 08:03 PM
Thanks
Thanks for your help!
