install laminate "backwards"
Old 10-03-06, 07:28 AM
R
i want to replace one piece of my finished laminate floor, as it happens, the first piece i installed. i used the standard method of installation, going from left to right, away from the wall. now, to do what i want to do, i ahha to re-install the first piece of flooring, but need to squeeze it into the piece in front of it and next to it - ie backwards.
has anybody done this; any special problems; any suggestions or tricks to make it easier??
when i took two loose peces and tried to fit them together "backwards", they did not want to snap together.
Old 10-04-06, 05:08 AM
Cut the locking lip off one board or the other. Then a little tiny bead of glue and slide it in and compress it tight so no cap. Then masking tape it to the installed plank, to hold it tight.
Old 10-04-06, 07:30 AM
R
perry
i still have a beginners question. which is the locking lip- the wide side or the narrow side?? these inidividual pieces are about 16" by 4 feet and are made to look like spanish floor tiles.
thanks, werner
also, WHAT KIND OF GLUE IS BEST??
