Floating hardwood floor????
Old 10-05-06, 01:35 PM
C
Is it possible to lay a floating hardwood floor on to particle board?? there is laminate down at present.
Old 10-05-06, 01:42 PM
T
Received 2 Upvotes on 2 Posts
Floating flooring can be installed over particleboard subfloor as long as it is flat. If existing laminate is floating, it will have to be removed first.
Old 10-05-06, 03:08 PM
C
Thanks, would it have to be the engineered stuff or could it be solid?
Old 10-05-06, 08:32 PM
It is not recommended to attempt to float a solid.
