Gap between floor edge and front door transition
Old 01-15-07, 07:38 PM
K
I laid down a laminate floor and left the required gap along all edges, including where the floor meets the transition piece to our front door. However, the front door transition piece didn't have a "lip" (i.e., it wasn't a T-molding shape) that the planks could "disappear" into, so I ended up a with an obvious gap.
You can see a picture here:
http://img471.imageshack.us/img471/664/img3861smallen8.jpg
I'm going to redo the whole floor soon. Do I need to replace the metal transition piece with one that has a lip (like a T-molding). Is that the only way to handle a situation like this?
Thanks.
Kurt
Old 01-15-07, 07:42 PM
T
Received 2 Upvotes on 2 Posts
T molding is used in a gap between two solid surface floor coverings of the same height. Does your flooring manufacturer have a baby threshold to cap over end of boards and fill the gap?
Old 01-15-07, 08:11 PM
End cap molding!!!! Sometimes called a carpet reducer or baby threshold. It is the shape of an "L" turned on its side so the leg goes down next to the metal threshold.
Old 01-16-07, 10:51 AM
K
Ah! So obvious. Now why didn't I think of that?
Thanks!
Old 01-16-07, 07:44 PM
I
Lets give him the right one guys...
Not one he will have to modify.
A baby threshold will not work here without extensive modification nor will a carpet reducer.
Here is a link to the proper end cap style. The lip on it is small enough to fit in your expansion gap with no modification:
http://www.tradekey.com/selloffer_view/id/95607.htm
It is the one in the upper left hand side, when you see it you will know just what do.
Old 01-20-07, 08:16 PM
mcm
mcm is offline
FWIW, I made my own threshold out of a slab of red oak for this exact problem. If you have an accurate table saw/cabinet saw, this is fairly simply to do, and the advantage is you can tailor the overlap/gap etc to your liking, plus you can find a stain to match the wood flooring and make it look a little more seamless when looking at the door (closed or open).
Old 01-22-07, 09:41 AM
Why won't it work? Here it is working
Picture link below:
http://i-boards.com/bnp/fci/images/messages/MVC-141S_1.JPG
Old 01-22-07, 11:41 AM
mcm
mcm is offline
Custom option:
http://img252.imageshack.us/img252/2172/doorthreshold23im.jpg
http://img262.imageshack.us/img262/4944/doorthreshold32us.jpg
(This was with one coat of stain, I ended up filling the screw holes and putting on another 3 coats which shifted the colour to something very similar to the flooring).
