Laminate Installed Over Carpeting!
Old 01-23-07, 09:08 AM
A
Angry Laminate Installed Over Carpeting!
We just found out the previous owner of our multifamily put new laminate flooring over existing carpet & padding in the kitchen, living rooms and bedrooms in every apartment!
does anyone know what problems this could cause?
Old 01-23-07, 09:29 AM
Check out this thread. We just covered this yesterday.
http://forum.doityourself.com/showthread.php?t=291811
Old 01-23-07, 09:45 AM
A
Have you ever heard of this contributing to a pest/insect issue? Tenants have complained of bedbugs...
THANKS
Old 01-23-07, 09:57 AM
NO, I haven't, but it's certainly not outside the realm of possibility. There's no telling what's in the carpet they covered up. Anyone who would do this would appear to be a "corner cutter" and may have been trying to eyewash a problem to make a sale. I believe I'd be pulling the laminate up, removing the carpet and pad, cleaning and fumigating, and re-installing the laminate with the proper laminate pad and vapor barrier. More labor than materials so, if you do it yourself, it may not cost that much. This, of course, is dependent upon the laminate not being glued together.
Old 01-23-07, 11:49 AM
Annette's Avatar
absolutely DO NOT WALK ON THE FLOOR anymore! with every step, the planks are being damaged. if it's click-together floating laminate (and NOT glued together), you can disassemble the floor. DO SO IMMEDIATELY! then do as previously stated, and then you'll be able to REUSE the floor, and relay it.
but stop walking on it right away, or you'll snap off the tongue & groove connections and the edges will start to chip & it'll be ruined.
