My gaps are too big! Help
Hi all, I have just fitted my first laminated floor in my hall. Everything is fine except in a couple of places the gap between the flooring and my walls are too big for the beading. What can I use to fill the gaps please? I bought some wood filler but didnt see till i got home that it is not for use with laminated floors!
thanks
thanks
Depending on your baseboard/wainscoting you may be able to build up the depth of the baseboard by putting a "shim" panel behind it.
Or you can go the quarter-round route, but I think that look should be avoided if possible.
How big are these gaps anyway?
