Dirty scratches, heated floor
Old 03-10-07, 01:12 PM
L
I just moved into an apartment with an area of horrendous scratches on the light colored wood floor that may have absorbed a lot of dirt. What can I do to make this area look better?
I should mention that I'm currently in Korea so the apartment has ondol heating (hot water pipes under the floor heat the room) so if the solution requires putting a substance on it, I'm guessing it shouldn't be heat sensitive.
Here's a link to a picture of the floor to give you a better idea:
http://i21.photobucket.com/albums/b300/stinkyllama/DSC09960.jpg
Old 03-10-07, 06:04 PM
Sand it to good wood and make it smooth, Several coats of urethane.
