5x1/2'' ENG HRD WOOD FLOOR INSTALL QUESTION
Old 05-04-07, 01:41 AM
F
Question 5x1/2'' ENG HRD WOOD FLOOR INSTALL QUESTION
Can Anyone Give Me The Preferred Method Of Changing Directions Of T&g Where I Have An Opening In My Dining Room That I Want To Work The Opposite Way From Starting With A Groove But I Need A Tounge. The Reason I Want To Do This Is Because I Want To Use The Entry Way As A Starting Wall 33' Long And Work Away From It For The Rest Of The House And Then Work The Opposite Way Into That Dining Room,
Old 05-04-07, 07:48 AM
R
Your goint to need a transition piece, t-molding. I think this would be the easiest way. I have read other ways on this forum that are a bit more detailed. Try some searches on changing direction.
Old 05-04-07, 06:58 PM
Start the area so when you come across the place you want the direction change, the tongue is facing outward, and start the installation right there.
Then you will need a router and a slot cutter with a top bearing, to put grooves in the end cuts. This saves having to groove and spin a rip cut board, or have a sliver rip right where you want to transition.
