Vapor barrier?
Old 05-28-07, 12:03 PM
L
Vapor barrier?
Is a vapor barrier the same as underlinement?
Old 05-28-07, 12:21 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
No. Underlayment can be considered your subfloor, i.e. plywood, OSB, thinset, etc.
Vapor barrier is plastic sheathing attached to the subfloor.
Old 05-28-07, 11:12 PM
L
OK that makes sense. When I had my laminate installed they used a vapor barrier that came in a rioll. Now I want to add more (different manufacturer) and the vapor barrier is attatched to the bottom of the laminate.
Old 05-30-07, 09:18 PM
No, that is not the moisture barrier. It is the underlayment cushion. A vapor barrier is sealed plastic, with a good perm rating.
If your going over a wood substrate, you will not need an additional moisture barrier. Over concrete, you will need to buy some 6 or 8-mil plastic
Old 05-30-07, 11:05 PM
L
I am going over concrete, so even with the underlayment that comes with Dupont laminate flooring I will need to lay a vapor barrier?
Old 05-31-07, 12:00 AM
T
Received 2 Upvotes on 2 Posts
Dupont says, "If installing over concrete or a concrete floor covered by tiles, you must first lay down a 6-mil plastic sheet vapor barrier."
If in doubt, contact Dupont at 1-877-43-TOUCH or 1-877-438-6824 or flooring@mail1.dupont.com.
Old 05-31-07, 08:15 AM
That underlayment on the back of the laminate is not vapor barrier. It's just a cushion.
Do as the others suggested and lay down at least 6-8mil plastic vapor barrier.
Tape all seams and have it go up the walls 2". (the baseboards will cover it)
