Holes from carpet tack strips
Old 06-03-07, 09:47 AM
Hello all,
I am getting ready to "attempt" to install Uniboard Pacifica Lock'n Seal laminate that I purchased from Sams club. I am currently in the 48 hour acclimation phase and will start install on Monday.
I pulled up the carpet and vinyl and have noticed holes/dents where the carpet tack strips were pulled up. Do I need to fill these in prior to installation. If so with what?
Thanks for any help you can provide.
~Maria
Old 06-03-07, 09:52 AM
jatco's Avatar
Received 2 Upvotes on 2 Posts
You could if you want, with some floor leveling compound, but I dont think it would be necessary..as the X-tack strips/holes should be pretty close to the wall (what-about an inch or so off the wall) and shouldnt interfere with the way the laminate lays there.... So long as there are no raised bumps
Just my $.02 worth.
Old 06-03-07, 03:15 PM
Since it is so close to the wall, no, they don't "need" to be filled. Across trasition areas, I like to fill them, so the transition molding has a flat surface to mount to.
