Laminate between rooms.
Old 07-01-07, 11:20 PM
L
I am laying laminate down a hallway and into 3 bedrooms. Do I need a strip between the hallway and the rooms or can I make it continuos. The doorways are standard 30 inch.
Old 07-02-07, 06:32 AM
Technically, yes, you're supposed to use transitions at the doorways so the rooms can move independent of the hall. Personally, I don't like that look, have installed several jobs without transitions, and, as yet, have had no problems with it. Your call.
