hardwood floor under carpet
Old 10-11-07, 10:25 AM
L
I tore up the old carpet and found hardwood floors under there. the house is old (not sure how old). The padding was glued to the floor. Any advice on how to remove the glue?
Old 10-11-07, 10:57 AM
D
Received 2 Upvotes on 2 Posts
Hi LuckieGirl, welcome to the DoItYourself.com forums
Here's a previous thread similar to yours that should help you out:
http://forum.doityourself.com/showth...+from+hardwood
Old 10-11-07, 01:09 PM
Received 1,281 Upvotes on 1,219 Posts
Didn' hit DIYaddict's link, so I may be repeating myself, but here's all you need:
Mineral spirits
Elbow grease
Good ventilation
Tedious, but it will work.
Old 10-12-07, 05:16 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
You're gonna have to sand it and refinish it anyway, so I would use the solvents mentioned with a flat scraper, take 90% of it off , then use a ScotchBrite pad on a floor polisher to remove the rest.
