finishing stairs
Old 12-23-07, 08:51 PM
finishing stairs
All,
I need some advice.
We will be moving into a new house in a few months. Builder is going to leave our stairs unfinished. We'll need to match color of these oak stairs to the pre-finished oak hardwood that will be installed by the builder on the second floor.
I realize perfect match would be impossible to achieve.. but how should we approach this?
I also have a question on the sequence of finishing job, do I have it right? So far I plan to do the following:
I uderstand I need to do coats of
SEALER-STAIN-TOP COAT, but unclear of how many...
- sand by hand with 120 grit sand paper
- vacuum
- wipe with dry (or wet?) rug
Coat 1 - sanding sealer
- apply sanding sealer with a brush
- wait to dry
- sand with 220 grit paper and wipe with a clean rug
Coat 2 - stain
- apply stain with a cloth
- wait to dry
Coat 3 - PU top coat
- apply polyurethane with a brush
- wait to dry
Coat 4 - PU top coat
- wait to dry
DONE
I am also told I'd have to re-paint the walls, because the water based stain is very runny and splashes everywhere...
Old 12-23-07, 10:14 PM
You don't use sealer, if your going to stain. You want the cells open to accept the stain. The stain is the sealer.
