Interior Door Thresholds - How to attach to concrete slab
Old 01-14-08, 10:42 PM
I am requesting recommendations on how to attach wood interior door thresholds to a concrete slab.
The interior door thresholds will be used as transitions from laminate flooring in a hallway to each bedroom where carpet will be installed.
I had custom interior door thresholds milled because the trim that came with the laminate flooring popped loose on a daily basis.
I guess my options are to use Liquid Nail or some type of concrete screw.
HELP!
Old 01-15-08, 05:52 AM
When I did mine in Texas, I found wood plugs meant for putting threshold screws into concrete. Drilled about a 1/4" hole and used a regular wood screw. Could probably use a nail too, but I don't know.
