Laminate transition piece for closets?
Old 01-16-08, 05:35 AM
W
Received 4 Upvotes on 2 Posts
I am putting in laminate and it will extend into the closets. Should I make a transition piece (T-mold) for the closet like I do the rest of the doorways?
What about closets that have 2 folding doors?
Old 01-18-08, 03:22 PM
D
Received 2 Upvotes on 2 Posts
Hmmm...I think your thread has been missed
This previous thread might help out a bit.
http://forum.doityourself.com/showth...set+transition
So...how big is the closet? Which way do/will the planks run?
Old 01-18-08, 03:40 PM
W
I have 4 closets that will be "laminated".
3 of them are in the neighborhood of 6' x 2' with two folding doors. I have not finalized the flooring direction yet, but probably 90% sure the planks will run parallel to the opening.
The other one is in the neighborhood of 4' x 2' with a standard door. Again, haven't finalized the flooring direction, but the planks will probably run perpendicular to the closet (the planks will run into the closet).
