Paint on laminate floor
Old 01-18-08, 09:16 AM
Oil based paint spills on floor. I've tried rubbing thinner with a soft cloth, but no results. I'm afraid to even try a fine steel wool
Anybody have any experience on this?
Thanks
Old 01-18-08, 04:51 PM
Received 169 Votes on 150 Posts
What kind of paint spill??
If it is mostly specks, your best bet is to very carefully scrape them up.
If it was a paint can knocked over it should all be wiped up while still wet and rinsed with clean paint thinner.
A large amount of dried oil base paint would mean sanding it off and refinishing the wood - if that's even an option. Not all laminates can be sanded and refinished. It may need to be replaced
Old 01-18-08, 05:16 PM
As agreed. IF it's laminate wood (not real wood..plastic on top, photo of a wood), don't sand it as marksr indicated.
I have laminate wood flooring and I once had SOMEONE draw on a paper with a gold glitter marker and it went right through the paper onto the floor. I used nail polish remover (w/acetone). It worked. I had to use a lot of elbow grease though. I put the nail poilsh remover on a paper towel first and just started elbowing away.
I hope your spill wasn't major
If they're specks, have you tried using your fingernails? Not sure that'd work, but worth a shot.
Old 01-19-08, 06:01 AM
That is probably the best 'tool' for removing specks of paint
