Caulk exposed gaps in laminate and trim?
Old 02-04-08, 12:15 PM
Received 2 Votes on 1 Post
I am installing laminate and as you can imagine I have made a few mistakes in some places. I wasn't perfect in measuring and cutting as I installed under door jambs and things and now I have a few spots where there is a gap between the laminate and the jambs.
How would you best advise to cover/mask that hole? Caulk? Duct Tape? A small sign that says "My bad!"?
Old 02-04-08, 01:23 PM
BEST advice is to not mask it Sorry! I'd definitely, definitely, uninstall and re-do it so there's no gap. Duct tape? No way...
Old 02-04-08, 04:30 PM
Received 170 Votes on 151 Posts
If you undercut the jamb or casing too high - caulk
If the laminate doesn't reach the jamb - install a new piece of laminate.
or you could use duct tape and say you subbed the job out to McGyver
Old 02-04-08, 09:48 PM
once the tongues and grooves have been locked in and then taken out, are they worthless?
