Laminate Tile
Old 02-10-08, 04:13 PM
R
Laminate Tile
WHICH IS THE GROOVE AND WHICH IS THE TOUNGE?
IS THERE A SECRET TO THE "TAPPING" THE TILES TOGETHER,SO ITS EASY?
ITS THE MOHAWK INSTA CLIC.
Old 02-10-08, 04:23 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
The tongue will be sticking out of the board, and the groove is just what the name says, a groove in the middle.
Laying laminate flooring is fairly easy, but if your already asking what the tongue and groove are, your installation might take a little longer....
Use use a tapping block to just tap the board so it is tight against the other planks.
