transition between rooms
Received 0 Votes
I am preparing to install a floating engineered wood over ongrade concrete slab. I have several 4ft doorways and 2 ten foot openings. I plan to put "t" moulding in the 4ft doorways, and likely will be changing direction of the boards to match the way the light enters the room. With the 2 large openings...
Is it acceptable to not use a gap and "t" moulding? One opeing has no furniture and used as a walkway between 2 large rooms.
