glueless laminate system
Old 05-03-08, 01:38 AM
B
I bought 352sq ft. of glueless flooring from home depot-trafficmaster, southern oak. my question is I have installed it over most of the floor but it seems to be coming apart in places. spaces where they join together on the ends. should I glue the ones with spaces or should I get them tight and put screws at the wall end so they dont move. yes they are on padding made for this, over plywood. thank you in advance.....
Old 05-03-08, 06:37 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Hi!
When you installed them, did you use a tapping block to securely fasten them into the adjoining planks?
Did you leave the required expansion gap along the walls?
Is this flooring on the second floor, above a crawlspace?
Did you also install a 6mil plastic moisture barrier?
Old 05-03-08, 09:07 AM
B
laminate flooring
tapping block made for this flooring,fiberglass. 1/2 " expansion gap all around room done and yes a foam underlayment water vapor barrier...over plywood,.all done on the first floor of house.
Old 05-04-08, 09:36 PM
Isn't that a full rotating lock laminate, where taping the ends damages the lock??
Old 05-08-08, 12:45 AM
B
laminate floor
this is a floor bought at home depot. trafficmaster,glueless. it only locks on the with side not the ends. its all installed. what i did was nailed the end boards at the edge on one end of room. it seems to do the trick
