Help with wood to laminate transition Please!
Solid hardwood flooring will add value to your home more than laminate will..but is more expensive and time consuming on install. laminate i would think would still add valve to your home, be easier on the budget and install. I would try to stick to a similar color. if you sell your home in the future it will add to the resell value. Cant really base the floor coloring on the paint..as if you sell the home..the first thing they may do is paint the walls.
