12 mm too thick??
Old 07-11-08, 07:13 AM
D
12 mm too thick??
I'm planning on putting 12mm laminate for my floor.My question is if this is going to be too thick as I am putting electric floor heat under it? Would I be better off going with a little thinner one say 8 or 10mm for better heat or will I even notice a difference?
Old 07-14-08, 09:24 AM
D
Received 2 Upvotes on 2 Posts
Not the pro around here but since no one responded yet...
Whatever brand/manufacturer you choose for your laminate wood flooring, check the specifications/instructions as to what they say about it. There should be some type of instruction regarding this. If it does not, give them a call and find out.
BTW: Welcome to the DIY forums
