LAMINATE: liquid nails
Old 07-28-08, 01:19 AM
I will have several transitions from laminate floor on concrete subfloor to tile (reducer), wood (T-molding) fireplace (end-cap). The prospect of drilling concrete floor to put in the u-track of the transition is not very thrilling. I have failed terribly before when putting in molding between carpet and tile floor. I broke several drill bits and gave up.
I just found out that you can use liquil nail to fasten the u-track to concrete floor ( ) Well, liquid nail website shows a total of 60 adhesives, probably with a devious purpose of confusing novice like me.
In short, which liquid nails should I use for u-track transition strip ?
Nathan
Old 07-30-08, 03:39 PM
srickard's Avatar
I used Liquid Nails (clear) to fasten the U-tracks that hold the transition pieces to the slab. I bought it at Home Depot. It was a tube of clear. It works very well but be sure that the concrete is very clean where the strip is placed. To make sure that things were aligned properly I first mounted the U-track to the T-molding. This allowed pre-fitting. Then I applied the glue to the bottom of the U-track and pressed everything into place. I placed heavy objects on top (books in my case) and let it dry several hours. Where I used a reducer from the flooring to tile, I also glued the reducer to the tile. A year later and everything still holds well.
Old 07-30-08, 03:52 PM
HotxxxxxxxOKC's Avatar
PL400 is even better.....
Liquid Nails is also decent stuff. Ignore the website you looked at, just go to a Home Depot or Lowes and go to their paint department. They have a couple different types, but all will work for you.
Old 07-31-08, 12:24 PM
Thank you guys for your great tip. -- Nathan
