Laminate floor dull splash stain
Alcohol was spilled on my laminate floor and not immediately mopped up. Now there is a dull area in a splash pattern. Is there any way to resore this area?
Alchohol, if not immediately wiped up, WILL do permanent damage to the Aluminum Oxide finish on laminated floors or other finished hardwood floors.
Check with the manufacture of your laminated floor to see if they have a solution FIRST!
Depending on the installation method used when your laminated floor was installed, it may be easiest to remove the damaged boards and replace them (this is not true for glue downs, but it is still possible). If it is a "snap lock" laminate or "floating floor", this method is quite simple an your manufacture can guide with this repair.
Check out this particular manufactures site (Mirage) for some ideas:
http://64.233.167.104/search?q=cache...lnk&cd=2&gl=us
Regards,
Greg
Maine
Regards,
Greg
Maine
