repairing scratches on hardwood floor
Old 08-08-08, 03:26 PM
G
Hello,
I have hardwood floors. I've made a nasty scratch in them. I was moving the fridge out and on of the corners scratch my hardwood floor as it came out. How does one go about repairing this? Is there a polish I can use?
Thanks for any forthcoming help.
Old 08-08-08, 03:46 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Is your floor a prefinished wood, or was there a finish applied after it was installed?
Old 08-08-08, 05:42 PM
Received 873 Upvotes on 764 Posts
How deep is the scratch? Is it thru the stain? with or against the grain?
Old 08-08-08, 07:15 PM
G
There was a finish applied.
It doesn't seem that deep. It looks like it just scratched the finish. It zig-zags back and forth so it goes with the grain at some points and against it at other points. I don't mind if I have to live with a slight groove in the wood, so long as I can make it less visible. The wood is a deep brown/purple and the scratch is a bright white color. If I could get it more or less camouflaged with the wood, that would be fine.
Old 08-09-08, 04:00 AM
It sounds like you just scratched the finish and didn't get into the stain or wood. Wiping it with a rag damp with mineral spirits might remove the 'white'. Ideally you would lightly sand and recoat with poly. You would need to stop the poly at the end of the pieces of wood so it wouldn't be overly noticable. You might get by with just waxing it.
Old 08-11-08, 07:37 AM
G
Thanks marksr,
I'll give those suggestions a try.
Old 08-12-08, 07:15 AM
G
Originally Posted by gib65
Hello,
In your post(s) you never say if this flooring is Prefinished from the factory, or if it was site finished by a hardwood flooring finishing company...
Also, if it was finished on site, what type of finish was used (waterbased or oilbased)?
The answers to these two questions will GREATLY effect on how you proceed with the repair(s). You say that the scrached areas are "white". This more than like means that the layers (coats) of finish were crushed and you are seeing a lift in the finish.
There are different approaches, but PLEASE get back to me with the answers to the above questions.
Greg -Retired Hardwood Installer/Refinisher
Maine
