Concrete Crack
Old 08-12-08, 10:50 PM
Post Concrete Crack
Getting ready to put in laminate wood flooring and after removal of the carpet we have found a crack in the concrete. I have been all over the internet for specific instructions in this case and have not really found any helpful guidelines.
Any suggestions?
Thanks!
Old 08-13-08, 06:04 PM
C
is one side of the crack higher that the other side ? by how much ?
Old 08-13-08, 06:32 PM
Yes one side is higher maybe up to 1/8". The two adjoining sides of the crack form a peak.
Old 08-14-08, 06:26 PM
C
i am not a pro at all. but i have a crack in my slab. i was told that if its perfectly even, it was ok, as mine was. otherwise do not install wood. BUT, i may be error on this. search this forum for the work "crack" and that should bring up the advice you seek.
Old 08-14-08, 07:15 PM
D
grind the high side then float it out to the floor manufacturer's spec for flatness
