Laminate Flooring Problem
Old 09-19-08, 09:00 AM
C
I bought a house that has laminate flooring throughout the house. However, whoever put it in, tried to put corner round around where the doors are and it does not look right. I thought if I could cut the bootom of the door frame and slide a new piece under it, then it would work.
Will this work and how would I go about it? They did it at every door and it looks like a jigsaw puzzle.
Thanks
Old 09-19-08, 09:08 PM
Remove the "T" molding that is required at every door. Remove the flooring back, Undercut the doorjambs. Install matching flooring, if you can find any, and replace the "T" moldings.
