Installation Help for Engineered
Old 09-23-08, 09:20 AM
Hello All,
I am doing my first engineered install and the instructions from the vendor say to float it by gluing the edges.
I am wondering.... is it ok to use a brad nailer to just fasten it to the OSB subfloor?
The flooring is 3/8 by 3" by random lengths.
I have the underlayment for the moisture barrier to go on top of the OSB.
Thanks,
Dean
Old 09-23-08, 08:31 PM
It is OK, if you want a squeak factory.
If it is a floating design, ONLY, don't try to reinvent the wheel. There is a good reason it is floating only. It problably has a sloppy fit on the T&G to accept the glue, so it won't hydroloc, from joint compression, upon installation. Float it using a PVA Type II adhesive, Like Frankin's Titebond-II and the use of strap clamps to get good compression, and approved blue painters tape, to hold things together, while you get another bite with the strap clamps.
Old 09-24-08, 06:25 AM
fyi... DO NOT use warped boards ! even if the instructions say its ok.
been there, done that.
Old 09-25-08, 06:19 AM
Thanks for the advice... what are strap clamps?
Old 09-25-08, 06:25 AM
Old 09-26-08, 06:35 AM
Do a google search.
They are a must in any glue together floor. All craftsmen, clamp their glued together projects.
