Transition Molding Inlay
Old 10-16-08, 11:34 AM
T
Question Transition Molding Inlay
We recently laid/had someone lay a laminate floor throughout our downstairs. Unfortunately, our installer installed several transition moldings and then ran out. By the time we ordered more, he couldn't return to finish. We laid a portion of the floor ourselves and have done others, so have some experience.
When he installed the transition moldings, he cut into the already laid foor and inset/inlaid the transitions so that they were flush in height with the floor. He allowed for a gap which was filled with a special caulk. It looks fantastic.
My questions are: Is there a special tool to cut the floor with or is it a standard table saw? If so, is there a special blade? Also, what type of caulk should be used to fill the gap?
Old 10-16-08, 06:10 PM
A
A hand held circular saw, set to the proper depth will work fine. You'll need a hammer and chisel to get close to any walls as the saw will come a bit short.
Caulking is unnecessary. The gap is covered by the molding.
Old 10-16-08, 06:51 PM
T
Thanks for your response Arkon.
I did a little more reading online and found that a router can be used to make a clean edge, as long as I use a guide. I'm not sure which would be better, a circular saw or a router. There is a slight gap because the floor molding does not overlap the laminate floor. It overlaps the floor that it transitions to, usually some type of tile.
Laminate caulk transition tile
molding
I exaggerated a bit to fit the words, and in reality, the laminate and molding are the same height while the tile is slightly shorter.
