polyurethane finish patch?
Old 11-29-08, 05:33 PM
Hello,
I recently installed, sanded and finished about 500 sqft of unfinished red oak T&G flooring. I just applied the final coat of polyurethane (Minwax Fast Drying Polyurethane, satin finish).
Everything looks great except for a small section about 1' x 1', which has some bubbles. I sanded it lightly with 220, and want to repair it. what is the best way to blend it?
thanks in advance!
Old 11-29-08, 06:07 PM
Received 167 Votes on 148 Posts
You can't effectively blend in the poly. What you sould do is poly completely each affected board - just to the next joint. It may show for a little while but it will blend in given a little time.
Old 11-30-08, 06:15 PM
thanks for the advice- i tried it and it seems to be the most subtle way to patch the area. Thank you!
