Removing & Saving Laminate Flooring
Old 12-10-08, 10:57 AM
Please tel me how to temporarily remove a laminate floor that will be put back down in another location.
Old 12-10-08, 11:32 AM
removing laminate flooring
if you take the base trim off. you can then usually pull up the flooring. sometimes a few boards will get damaged. if its a click together floor you shouldn't have any problem's. if it's glued together it won't be reusable.
