underlayment under 3/4" over basement?
Old 12-12-08, 08:18 PM
I am going to begin laying 3/4" Solid Santos Mahogany 5" planks tomorrow. The subfloor is plywood, and is over a basement with temperature control. My question is, Do I need to put down an underlayment, or can I just nail my planks directly onto the subfloor? (after ensuring subfloor is nice and flat of course...)
Old 12-12-08, 08:30 PM
HotxxxxxxxOKC's Avatar
Hi!
How thick is this plywood? You say basement, so is this wooden subfloor over slab?
I would install some 15lb roofing paper over the plywood as a vapor barrier.
What is the humidity like down there?
Old 12-12-08, 09:17 PM
Not sure of the thickness of the plywood. Does it matter? The basement (and the whole house) is very dry. Actually thinking about adding a humidifier to the hvac unit... I don't have any tools to measure humidity in the basement, but upstairs the humidity is 42%. What does the vapor barrier do? Just helping with moisture control? The basement is poured concrete. with insulation on the walls.
Old 12-13-08, 12:11 PM
Well, you can't nail a 3/4 solid to a piece of paper now, can we?
Vapor barrier prevents moisture from the subfloor getting to your floor covering.
