Bad Laminate install
Old 01-02-09, 06:51 PM
Question Bad Laminate install
I installed my floor last year, and had some problems with it , so after throwng tools and other things around, I stupidly decided to trim the ends and sides to make it fit together, now the boards are coming apart, I tap them together, and they start to buckel, so thsi is n question.
If I brad nail all the boards to the floor, would this cause a problem except when if I try to remove them?
Please help, I have my nailer ready and waiting.
Thanks,
Old 01-02-09, 06:55 PM
HotxxxxxxxOKC's Avatar
It will most likely split the flooring. The floor needs room to expand and contract.
So, you basically removed the tongue and groove of the boards?
Old 01-02-09, 08:00 PM
If you don't follow manufacturer's installation instructions, you void warranty and set yourself up for flooring failure. Sorry, but a nailer in hand will not solve your problems.
If you have laminate install problems, read the manufacturer's instructions. If in doubt, contact the manufacturer.
Old 01-02-09, 09:44 PM
I basicly removed some of the tongues, does this stuff expand and contract a lot, and if I use finishing nails will it still split?
Old 01-07-09, 02:22 PM
He says that it will most likely split, but if it looks bad already then what do you have to lose.
