Rounded transition between tile & wood
Old 01-05-09, 09:35 PM
Wink Rounded transition between tile & wood
OK--I'm probably over optimistic/ambitious: I have a round shaped entry that I want to tile and I want wood laminate flooring to lead from the entry into the rest of the house. Do they make a round-shaped transition for use between the tile and the wood? Thanks.
Old 01-25-09, 03:15 PM
flooryou's Avatar
I made this molding, and it took about 3 days to complete the piece. so maybe you should just use angles for standard t-moldings.
Old 01-25-09, 03:54 PM
I am sorry, but the links would not work.
Old 01-25-09, 04:13 PM
Schluter Deco makes the transition between tile and wood and will form curves.
"The anchoring leg of Schluter-DECO, in solid brass, chrome-plated brass, and anodized aluminum, is available with a special radius perforation "R" so that the profile can be used to form curves. DECO in chrome plated brass requires a relatively large bending radius." Schluter-DECO - Schluter-Systems
Photo Credit: Schluter
Old 01-25-09, 04:16 PM
That is a totally awesome transition! I have never seen anyone do that before. Such beauty and craftsmanship achieved in a transition piece.
