Laminate in Mfg. Home
Old 01-06-09, 05:25 PM
Want to install 850+ feet of laminate flooring in my 3 year old "double-wide" home.
Solid with no shifting at this point (on concrete runners foundation).
My question: do I need to lay the laminate across the "marriage" seam of the home's two halfs or can I run in the same direction of the seam (length wise)?
Floor is absolutely level the entire width of home with no part of the seam raised.
Thanks.
Old 01-12-09, 12:32 AM
Which ever direction you lay the flooring, you should have a transition gap at the seam. This will accommodate movement. A T-mold is installed in the gap.
Old 01-12-09, 03:46 AM
T Mold
Thanks for the input.
So, the T-Mould is what I use as the transition strip?
Jeff
Old 01-12-09, 04:08 AM
T-mold drops in gap between two flooring surfaces of same height.
