Transition from laminate to thick carpet
Old 01-15-09, 08:31 AM
I am installing laminate flooring in a hallway and I need to transition to carpeting in two bedroom doorways. I have bought the transition kits with the Armstrong swiftlock flooring, but the carpet I'm transitioning to has a 1/2" thick pad plus a fairly thick carpet. The carpet side is actually higher/taller than the laminate side. Any ideas. Thanks.
Old 01-15-09, 09:16 AM
T
What transition piece did you buy? If it were 3/4" solid hardwood, a baby threshold is used.
Depending on laminate manufacturer, the transition piece for carpet to laminate may be named differently. It could be called "End Molding Carpet Reducer."
Photo Credit: Shaw
Old 01-15-09, 10:18 AM
Transition from laminte to thick carpet
I have the exact transition in your reply. I assuming that I can just butt the carpet up to flat side of the transition using a tack strip to hold the carpet in place? Please let me know and thanks for your help.
