Laminate to Carpet transition
Received 0 Votes
I am putting a laminate floor in my living room and hall but the hall connects to two bedrooms that have carpet but the hall and living room is higher than the carpeted rooms. I don't want to pull the carpet up and raise the floors up so is there a nice way to transition from the laminate to the carpet?
Received 0 Votes
I had this exact same problem. I resolved it by glueing a solid hardwood shim to the reducer. Then I used a stain pen to stain the exposed face of the hardwood the same colour as the flooring. The finished reducer looks like a cross between a sloped reducer and a square reducer, but look and works great. Here's an illustration of what I did:
reducer.jpg - Windows Live
Received 0 Votes
Are you installing over ceramic tile?
If so the carpet should be tucked to it and the reducer should simply cover the edge.
If you are seeing the raw edge of tile or subfloor you should
shim the floor in the bedrooms up. Remove the tackless strip and use cedar shake ro carpet shims than restrip and retuck.
