Can I install solid hardwood floor parallel to joist?
Old 02-21-09, 08:53 PM
Is it ok to install T&G hardwood, 3/4 inch thick parallel to the joists. The subfloor is 1x6 pine installed 45 degree to the joists and over that is 1/2 plywood. Joists are 16 inch's on center.
I have a long narrow room and installing the floor perpendicular would just look dumb as it is so narrow.
thx
Old 02-22-09, 04:45 AM
chandler's Avatar
Received 3 Votes on 3 Posts
As long as you have adequate subflooring, you can run the flooring any direction you want, even diagonally! Quite often the direction of flooring is turned 90 degrees when you enter a room, so it is of little consequence. In addition, the T&G adds to the rigidity of the floor inherently by its thickness, T&G, and being nailed so many times across the spectrum. Go for it!
Old 02-22-09, 09:23 AM
So going over only 1/2 inch plywood with blocking between the joists is enough of a subfloor? (with the blocking).
What is the maximum distance for spread of the blocking?
The flooring is 3/4 x 4 t&g pre-finished Brazilian Cherry. there is t&g on the ends as well as the sides, which I think also helps.
thanks again.
