floor finish safety
Old 02-26-09, 09:15 AM
floor finish safety
I'm in the middle of refinishing my hardwood floors, and will probably start applying finish later today or tommorrow.
The question is about fire safety. I know when using alcohol based finishes it's necessary to extinguish any pilot lights in the house. I'm using an oil modified urethane. Normally I wouldn't risk it and just turn off the pilots, but the weather is quite cold here at the moment. I'm worried about not having any heat, and applying finish in 35 degree weather.
The furnace and water heater are in the basement, and there are no fire hazards on the level with the floors being finished. Do I need to worry? Would covering the cold air returns on the 1st floor help prevent to much fumes from being taken into the heating system?
Old 02-26-09, 02:51 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Brand name please on the urethane.
I've looked up a few different brands, and the MSDS for them is showing it as combustible, keep away from ignition sources, and wear respirators.
I would make sure the area is well ventilated.
