Transition from 1/2" wood to 3/4" tile
Old 03-08-09, 11:21 PM
Z
Hello,
I am planning to install 1/2" engineered wood flooring that will butt up to existing 3/4" thick tile. I want a clean look at the transition, should I install 1/4" plywood underlayment or is there another way to make a clean transition since it is only 1/4". Thanks for your advice!
Old 03-09-09, 02:53 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Are you on slab or wooden subfloor?
If on wooden subfloor, yes, you can add 1/2" layer of plywood.
