Laminate in condo subfloor Please help
Old 05-04-09, 08:28 AM
Hello I would greatly appricate some help.
I have recently purchased 750 square feet of quick step country 2nds. I am looking to install in my condo. My condo is above grade with a 8inch concrete subfloor. I was trying to see if anyone can tell my if I could just use a 6mil cork rather than a 3-1. I understand about moisture barrier but i taped down a piece of plastic and found no sweating. Not really worried about warrent bc there 2nds and ther is none.
Please help
Old 05-07-09, 09:52 AM
You can do whatever you want but if you want to eliminate possible issues why wouldn't you use a moisture barrier. Especially with 750sqft. Forget warranty, think about the hassle if something were to go wrong.
Using cork is fine, but put down a 6 mil poly underlay first. The poly is dirt cheap so cost shouldn't be an issue. Don't put a 3in1 down and then the cork underlay. Just buy the poly sheet.
Old 05-09-09, 06:31 AM
Do you have a downstairs neighbor? If so consult your HOA to get their recommendation.
