laminate
Old 07-04-09, 06:30 AM
A
laminate
can you put laminate over carpet padding our do you need to remove it
Old 07-04-09, 06:59 AM
C
NO WAY. the pad is not firm enough.
Old 07-04-09, 07:01 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Agree. The pad is too thick and will cause floor failure. Use the prescribed padding specified by the manufacturer. Don't forget to pull all the staples from your carpet padding, too.
