Best Method of Seamless Transition into Another Room?
Old 07-09-09, 07:54 AM
A
Hi All,
I would like to laydown bamboo floors and have a seamless transition from the hallway to all the bedrooms (i.e. I don't want to cut a piece down so it end at the door frame). My question is once my first plank is in the room, where do I go from there? Do I finish the planks all the way across the room and work towards that closest wall? Or is there a better method. Thanks all.
Old 07-10-09, 03:53 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums!! Is this a laminate or full 3/4" nail down product? If full 3/4, do you plan on changing direction in the bedrooms? Looks pretty good, and makes the transition much easier. You just use transition splines to reverse the direction of lay. Laminate......different ball game.
