underlayment
Old 07-22-09, 08:45 AM
underlayment
I am installing a Pergo floor that has backing. I want to also put down underlayment. Is there any reason that I should not use underlayment with laminate flooring that has backing?
Old 07-22-09, 08:50 AM
Old 07-22-09, 10:54 AM
By "underlayment", I'm assuming you mean an additional foam pad for floating floors? I'm not sure what advantage you are trying to gain by doing so. I would not recommend it. Ignore the fact that one layer is attached to the laminate...it would be the same as installing a laminate with no backing, but rolling out 2 layers of foam under it -- by doubling layers, the floor will be spongy, and the laminate will deflect when you walk on it, eventually weakening the locking system.
Old 07-25-09, 09:42 AM
No extra underlayment needed. If you are on concrete make sure to put 6 mil poly down 1st and overlap 8".
Good luck
