What nail gun do I need?
I'm looking to lay some unfinished hardwood oak strips (5/16" thick) and I'm looking for the right nails and nail gun to use. I'm thinking of using 1" long, 16ga brad nails, I'm looking for the least expensive nail gun that will do the job. From the ones I looked at at Home Depot today, I need a big air compressor too? Someone told me that they make nail guns with an attachable compressed air tank, eliminating the need for an air compressor, but I have yet to find one.
Any ideas?
Any ideas?
Are you sure the unfinished oak is only 5/16 thick? 3/4" is the norm.
How much hardwood do you have to install? if it's more than a little bit you'd be better off with a floor nailer. They can be rented.
Nail guns don't usually require a big compressor. Even though they use in the neighborhood of 90 psi they don't require a lot of volume or constant cfm.
Hey, marksr. Yes, the strips are 5/16" thick (took me forever to find a place that sells it, too). I have about 150 sq/ft of floor to lay and the strips are going to be face-nailed. Do you think a cheapie $70 nail gun without a compressor from Home Depot would do the trick?
I think your on the right track with this one. If you done have a compressor this might be a good kit for you: Porter-Cable 1-Nailer & Compressor Combo Kit - PC1PAK at The Home Depot The store by me also has a kit with 3 guns, finish, brad, and narrow stapler, and a compressor that might fit the bill too.
