gaps in floorboards
Old 11-22-99, 04:27 PM
Guest
Post
my project is to sand the existing floorboards, but not wanting to lift floorboards and butt together, has anyone any
ideas on how to fill gaps so I can sand floor.
Guest
Post
What kind of floor, how big are the gaps, why do you feel the gaps need to be filled in prior to sanding?
Old 11-22-99, 04:28 PM
Guest
Post
The said floorboards are pine and one the ground floor in the house and therefore would like to cut down on drafts. I would like to fill first so as not to sand again after filling. If you can help I would be grateful
Old 11-22-99, 04:29 PM
Guest
Post
If your house has a crawl space, maybe you can go under it and fill the gaps between the boards in the subfloor instead of the main floor in the house. This would cut down on drafts and not ruin the appearance of your floor.
