Wooden Floor Restoration
Old 12-15-99, 04:49 PM
Guest
Question
I am currently restoring a late Victorian,ground floor flat. At present, I am trying to prepare the floor boards, in order to seal them. The problem that i am faced with is that before sanding them, I have to try and fill in the gaps in the tongue and groove flooring before sanding and sealing. I have heard that you can mix sanding dust with glue in order to give amatching finish. Has anyone any ideas?
Old 12-18-99, 02:00 AM
Guest
Post
The answer to your question exists here: http://woodfloorsonline.com/techtalk/glossary.html under "wood filler". The possible answers to your other floor refinishing questions are addressed also. The main page is: http://woodfloorsonline.com/
Old 12-19-99, 12:08 AM
Guest
Talking
Depending on the type of wood, it is usually NOT advosable to fill the seams in a floor, the floorboards have "shrunk" from age, and loss of moisture, wood is in constant motion and filling the seams will result in the filler "popping out" in a short time, your best bet, short of pulling and reinstalling, is to refinish the way they are.
